Tracing Images
Convert an image into vector lines with the Trace Bitmap command.
Import the image using either the File > Import > Import Image File or File > Import > Import PICT as Picture command. Then, select Tool > Trace Bitmap and specify the trace parameters. The image is converted to vector lines.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
