How can I change what the actual dimension reads on the screen?
It's easy to change the dimension display to something other than the actual dimension. Select the dimension, and then deselect the "Show Dim Value" checkbox in the Object Info palette Shape tab. Type the desired display information in the "Leader" or "Trailer" field.
To display information along with the actual dimension, leave the "Show Dim Value" checkbox selected. Text typed in the "Leader" field displays before the dimension value, while text typed in the "Trailer" field displays after the dimension.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
100% thumbs up 0% thumbs down (1 vote)
How would you rate this answer?
Thank you for rating this answer.
Continue
