Vista Tips
Vista's User Account Control
Vista User Account Control
Vista Compatibility
Technology update: Vista Compatibility
Vista Troubleshooting Tips:
Run as Administrator
In Windows Vista, VectorWorks should be set to 'Run as an Administrator'. Not only should you right-click on the VectorWorks icon and choose Properties > Compatibility tab and check the box that reads “Run this program as an Administrator,” but you should also make sure that under this same menu that you click “Show settings for all users” and check “Run this program as an Administrator," regardless of whether this user is going to use another account or not, it helps. Some machines even require you perform the same steps on QuickTime too. Reboot the machine, then restart VectorWorks.
Windows Vista Defender and Windows Vista Fire Wall-(Network Protection Error)
These can stop VectorWorks from communicating with the internet, QuickTime, the Aladdin Dongles among other things. Make sure Defender’s real-time protection is deactivated or at the very least, set to allow VectorWorks, HASP drivers and QuickTime. · To deactivate Defender; Start > Control Panel > Security > Tools > Options and uncheck the box that reads: “Use Windows Defender” under Administrator Options. · To allow VectorWorks through Windows Firewall; Start > Control Panel > Security > Allow a program through Windows Firewall. You will be shown a list of all software installed on the computer; you will have to check all instances of VectorWorks, along with any HASP drivers and QuickTime. Reboot the machine, the restart VectorWorks.
Check for Driver Updates
It is important to do with ANY Vista OS, however MUCH more important on machines that were either not originally shipped with Vista, or upgraded from Windows XP, that ALL hardware components in the Device manager be checked for online updates. (For this, they must of course be connected to the internet)
To do this:
Start > Control Panel > Hardware & Sound > Device Manager
The most important drivers to check are: · Display Adapter · Sound, video and game controllers · CD/DVD ROM drives · Universal Serial Bus controllers for HASP [:Dongle Troubleshooting - J:Dongles]
To check for updates, right click on each object in its subcategory, and then choose “Update Driver Software” then “Search automatically for updated driver software.” Reboot the machine, and then restart VectorWorks.
There is an error: “Buffer Overrun detected”
This error is in QuickTime, it will read that VectorWorks has crashed, but this error is QuickTime’s fault. Until a patch for QuickTime is released, there is no way of correcting this.
If VectorWorks palettes appears unstable, flicker or act otherwise odd (and you have already confirmed this is not a workspace issue) try turning off the Windows Aero theme.
To do this, go to: Start > Control Panel > Appearance and Personalization > Personalization > Window Color and Appearance and select Windows Vista Basic instead of Windows Vista Aero. As with EVERY Vista (or windows in general) settings change, you will need to reboot the machine, and then restart VectorWorks.
Installation
For Vista users who are having trouble installing, (Install fails, completes but there is no VectorWorks file, etc.) copying the program folder over from a successful installation will more than likely not work. Vista requires most programs to have been installed locally and not copied. Instead, the data from the install DVD could be copied to the working machines desktop, then transferred to the erring Vista machine and installed from there, there seem to be no problems with that.
Power Settings
On all Vista Machines, but especially laptop/notebook computers, the processor speed or power use may be by default limited to 50-75% of maximum capacity. This means that by default, you computer may only be functioning at half of its capability. This is useful for reducing power consumption when on a battery, but is relatively useless when the laptop is plugged in or using a desktop machine with effectively unlimited power reserves.
To change this; go to Start > Control Panel > Hardware and Sound > Power Options. Set the power plan to High Performance, then click Change Plan Settings > Chance Advanced Power Settings. Under the Processing Power Management list, expand Maximum Processor State.
If this was set to 100% already, you’re fine, but the default on most laptops is 50%. Change this to 100% and click Apply, then OK.
At the end of installing programs which were originally designed to work with XP, I see: "This program might not have installed correctly"
This happens with many, many applications in Vista, it is nothing you need to worry about. Click "This program installed correctly"
Serial Number Already In Use
On Vista machines both VectorWorks 12 and 2008 may encounter an issue where a dialogue box will appear, reporting that the serial number for this copy of VectorWorks is already in use.
This is normally caused by machines that have two network adapters. This is a very common setup for both newer desktops and recent laptops as they will have both an Ethernet port and Wireless 802.1xx adapter. Disabling one of these devices (preferably the one not in use. They should not both be in use) should stop the error from occurring in VectorWorks.
Driver Issues
See: Updating Drivers
Related Articles
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
100% thumbs up 0% thumbs down (1 vote)
How would you rate this answer?
Thank you for rating this answer.
Continue
