Adding Cells Together in a Worksheet
Start with a blank worksheet and duplicate the worksheet by typing the information in the corresponding worksheet cells.
Select the cell where the result of the addition is going to be displayed and type the "=" equals sign. Now, click on the Worksheet Menu button and select Paste Function. From the Select Function dialog box, select the SUM function. Now, select the cells range and click on the green check mark. You can specify the range of the cells by clicking on a cell and then dragging the mouse. You can also specify the range of the cells by typing the range (Example: B2..B5). The double periods designate the range of the cells.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
