Change a Plugin Objects Default Class
The class automatically assigned to a plug-in object can be changed through the Standard Naming dialog box.
1) Select File > Setup > Standard Naming.
2) Display the setup names for classes.
3) Select the reference naming standard and then select a custom active standard for the file.
4) Scroll to the class name to be changed and type the desired name in the Edit Class Name field and click OK.
All instances of that class name are updated to the new name.
Related Articles
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
