Add a Solid Color Background to a Viewport
How do I set a solid color to the background of a viewport, in order to block other objects behind it?
1) Select the viewport and access the Attributes palette.
2) Select the Solid fill style and then select the color you’d like to use.
This will fill any part of the viewport with that color, with the exception of existing geometry.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
