1. |
4. | Click Open. |
DWG and DXF files are produced by other CAD programs (such as AutoCAD®). To avoid unexpected formatting problems with DXF/DWG, import into a blank document. Vectorworks can import DWG/DXF files from version 2007/2008/2009 format or lower. DXF and DWG files can be imported as Vectorworks symbols, using the active layer’s scale. When a file is imported as a symbol, paper space objects are ignored. The symbol’s name is automatically assigned based on the original file name, without the .dxf or .dwg extension. | |
Encapsulated PostScript Files (EPSF) are produced by many graphics and desktop-publishing programs. EPSFs are typically high-resolution files, but will only display a preview image if one was selected when the file was created. | |
PICT files were first produced by MacDraw and other object-oriented drawing programs. PICT is also the native format of the Macintosh clipboard. PICT files imported into Vectorworks can be more than a single object, allowing image editing. Images imported with this command automatically have PNG compression applied. | |
PICT as Picture files are imported as a single graphic object. The following operations cannot be performed on this type of import: Trim tool, Clip tool, and Shear tool. Picture images retain picture comments when imported into Vectorworks. | |
Graphics files in the Metafile format can be imported from virtually any program, including AutoCAD and word processing programs. There are two versions of Metafiles: standard (pre-Windows 95) and enhanced. Vectorworks supports the enhanced version. Images imported with this command automatically have PNG compression applied. | |
Metafile as Picture files are imported as a single graphic object; the trim, clip, and shear operations cannot be used on this type of import | |
Vectorworks can import a variety of worksheet formats, including text, comma-delimited, CSV, DIF, and SLK. A worksheet must be open to receive the import. (To import a Vectorworks worksheet into the current drawing, use the Resource Browser.) | |
Imports 3D Parasolid X_T objects, including NURBS curves, NURBS surfaces, and solids; solids are imported as generic solids | |
During IGES import, points are imported as a group of 3D loci, NURBS curves are imported as a group of NURBS curves, NURBS surfaces are imported as a group of NURBS surfaces, closed solids are imported as a group of imported solids, and open solids are imported as a group of NURBS surfaces. If there is only one element in the IGES file, it is imported as a single element rather than grouped. Imported solids cannot be ungrouped or edited through the Edit Group command; they can be used in solid operations. | |
