1. Quit all applications.
2. Choose Start > Run (On Windows Vista, Type this into the Search bar directly), and type "msconfig" in the Open box. Click OK.
3. Click the Startup tab, and record all unselected items
4. Click the General tab, and choose Selective startup.
5. Deselect Load Startup Items. Verify that Process System.ini File, Process WIN.INI File, and Load System Services are selected (checked).
6. Click the Services Tab, and select Hide All Microsoft Services.
7. Click Disable All.
8. Click OK, and restart Windows.
9. Right-click icons in the Notification Area (called the System Tray in earlier versions of Windows) to close or disable any startup items that are still active..
Note: When you restart, you'll be notified that the System
Configuration Utility has made changes to the way that Windows
starts up. Click OK, and when the System Configuration
Utility appears, click Cancel.
Determining which startup item is generating the problem can be a tedious process. After determining that startup items are the problem's cause, break the list of items into halves. Test each half of the list to determine if a problem startup item is present. Continue to break the list in half until you determine what startup items are generating the issue. Do not leave any half untested. Multiple startup items may exhibit the same behavior.
1. Attempt to replicate the issue with all items disabled. If the issue does not occur, then proceed to the next section. Reenable startup items after all steps have been completed.
2. Restore half of the items that were disabled.
3. Attempt to replicate the issue.
* If the issue occurs, then divide the startup items in half
and determine which half the issue occurs within.
* If the issue is not reproducible, then enable half of the
remaining startup items. Continue dividing the items in
halves until you have determined what startup item(s) are
4. Once the problem startup item has been isolated. Contact the startup item's manufacturer for updates or configuration information.
1. Choose Start > Run, type msconfig, and click OK.
2. Choose Normal Startup on the General tab, click OK, and restart the computer.
Note: If unselected items were present on the Services or
Startup tab, then you will need to deselect them again.
