File Formats
Each version of Vectorworks has its own file version. (i.e. any file made in 2008 will have a flag that shows this when attempting to open the file in another version of Vectorworks.)
The previous extension for these files was .MCD, As of Vectorworks 2008, the new file extension is .VWX. Some older file formats are no longer readable by newer versions of Vectorworks regardless of backwards compatibility. Vectorworks 2010 and 2009 can open back to 2008, 12, 11, 10, 9, 8 and version 7 files. Vectorworks 2008 and 12 can open as far back as MiniCAD 8.
If you have a much older file from Blueprint or an early version of MiniCAD, you may not be able to open it with a modern copy of Vectorworks. If this is the case, contact technical support at tech@vectorworks.net
Related Articles
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
100% thumbs up 0% thumbs down (10 votes)
How would you rate this answer?
Thank you for rating this answer.
Continue
