Lock Files and the .lck Extension
In recent versions of Vectorworks, a "Lock" file is created in the same location as a Vectorworks file whenever it is actively open locally or over a network. This is done to prevent multiple users from opening the file once one user has already opened it. This prevents saving over files on a network and helps reduce the risk of file corruption from user error. This file will not be present if the VWX file is not open in any copy of Vectorworks.
The .lck file will not be visible unless Finder is set to "Show All Files" (Mac) or if Explorer is set to "Show Hidden Files" (Windows)
Related Articles
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
100% thumbs up 0% thumbs down (1 vote)
How would you rate this answer?
Thank you for rating this answer.
Continue
