Vectorworks & Mac OS X Snow Leopard V 10.6
FAQs regarding the compatibility of Vectorworks and Mac OS X Snow Leopard (V.10.6)
Apple has released Mac OS X Snow Leopard (V.10.6). Naturally, a number of questions regarding Vectorworks’ compatibility with this new operating system are coming forward. The following are answers to some of the more frequently asked questions;
Q. Is Vectorworks 2010 fully compatible with Mac OS X Snow Leopard (v.10.6)?
A.  YES. Vectorworks 2010 has been tested with 10.6 and it should install and run just fine at launch.
Q. Is Vectorworks 2009 fully compatible with Mac OS X Snow Leopard (v.10.6)?
A.  YES. Vectorworks 2009 has been patched to sp5, which makes it fully compatible with OSX 10.6.
Q. Will older versions of Vectorworks support Mac OS X Snow Leopard (V.10.6)?
A. Older versions of Vectorworks have not been tested on Mac OS X Snow Leopard (V.10.6). If you do attempt to run an older version of Vectorworks on Snow Leopard, you may encounter installation and stability issues for which there is no resolution. 2009 will be patched to work with Snow Leopard and 2010 was compatible at launch.
Q. What should I do if I have additional questions?
A. You can always email ( tech@vectorworks.net ) our technical support team for additional support.
Related Articles
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
100% thumbs up 0% thumbs down (11 votes)
How would you rate this answer?
Thank you for rating this answer.
Continue
