Open GL Faceting and Additional Options
When rendering in Open GL you experience faceting on the 3-dimentional objects, you may have your rendering detail set to low.
To correct this go to View > Rendering > Open GL Options, Click on the dropdown for Detail and set it to the desired between low-very high as needed.
Please keep in mind when increasing the detail you may notice a slight speed decrease to allow time to produce those finer details.
In this dialogue you can also:
  • Turn on Use Textures to show a quick low resolution view of the textures applied to 3D objects
  • Turn on Anti-Aliasing to further reduce any pixilation or jaggedness on the lines.
  • Draw edges will draw the edges around 3D objects in Hidden Line style.
  • Use shadows to see shadows cast on objects in the environment and adjust the softness resolution
Related Articles
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
100% thumbs up 0% thumbs down (1 vote)
How would you rate this answer?
Thank you for rating this answer.
Continue
