Wall Lines on Doors and Windows
A common question of Vectorworks users is how to remove the display of wall lines across Door objects in Top/Plan view so that the doors show as an opening.
There are two common mistakes, the first of which is that you may not be in Top/Plan view. If you are in Top view, you will see the wall lines continue though the door no matter how you modify your visibility settings:
The second (and more common) is that the Ceiling-Main class is enabled. This class controls the visibility of the wall lines that pass through window and door objects.
With Ceiling-main off:
With Ceiling-main on:
Related Articles
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
100% thumbs up 0% thumbs down (2 votes)
How would you rate this answer?
Thank you for rating this answer.
Continue
