Disabling the Windows Firewall
Under normal conditions, it is best to leave the Windows Firewall turned ON. However, when troubleshooting networking or activation issues in Vectorworks you should disable it to make sure it is not causing the issue.
Windows 7:
Go to Start > Control Panel and click "System and Security"
Then click "Windows Firewall"
then "Turn Windows Firewall on or off" and select "Off"
Windows Vista:
Go to Start > Control Panel and click "Security"
Click "Turn Windows Firewall on or off"
Select "Off"
Windows XP:
Click "Windows Firewall" and select "Off"
Related Articles
No attachments were found.
Visitor Comments
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
Bookmark and Share
User Opinions
No users have voted.
How would you rate this answer?
Thank you for rating this answer.
Continue
