Activation Error: System Clock has a Very Large Error
During the Vectorworks activation process, you may encounter the following error:
Most commonly this occurs when a user has modified the default settings on the clock or if the machine is relatively new. Regardless of how it occurred it can be fixed by doing the following:
Windows XP:
Right click on the clock in the bottom right corner of your screen
and choose "Adjust Date/Time".
Under the Internet Time tab, check the box for "Automatically sync with an Internet Time Server"
Select "time.nist.gov", click Apply, then reboot the machine and retry activating Vectorworks.
Windows Vista/Windows 7:
Right click on the clock in the bottom right corner of your screen and choose "Adjust Date/Time".
Under the Internet Time tab, select "Change Settings"
Check the box for "Automatically sync with an Internet Time Server"
OSX:
Click on the Date/Time at the top right of the screen and select "Date & Time Preferences"
On the Date/Time tab, check the box for "Set the date and time automatically:" then select "time.apple.com"
Restart the machine and retry activating Vectorworks.
Related Articles
No related articles were found.
No attachments were found.
Visitor Comments
